01-15-2020 12:19 PM
My PIXMA MX492 does not scan multiple pages now using the document feeder. It worked before but now I only can use the surface only. It also does not allow multiple pages to scan using the Canon IJ scan utility. Only 1 page at a time.
Any advice is appreciated as setting check or maybe reload scan utility ?
01-15-2020 12:42 PM
Hi norristowndave,
When placing the document in the automatic document feeder (ADF), your PIXMA MX492 should beep. That is the indication that your PIXMA MX492 recognizes that paper has been loaded in the ADF. For more information, please use this link:
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MX490%20series/EN/BG/bg-loading4300.html
Once the document is loaded, please use the IJ Scan Utility to scan.
Open the IJ Scan Utility and click the Settings button. In Settings, click on Document Scan on the left side. On the right, next to Select Source, please make sure that Document (ADF/Platen) is selected and click OK.
Click the Document button on the IJ Scan Utility to scan:
(Windows) https://ugp01.c-ij.com/ij/webmanual/ScanUtility/W/MX490%20series/1.1/EN/SU/Top.html
(Mac OSX) https://ugp01.c-ij.com/ij/webmanual/ScanUtility/M/MX490%20series/2.0/EN/SU/Top.html
01-15-2020 12:51 PM
Thanks for the advice and answers. I checked the steps and settings but the auto feeder does not grab the paper, it did beep. Is there something to verify the document feeder is working?
01-16-2020 02:39 PM
Hello.
Are you using the "Document" option in the IJ Scan Utility program or are you using a different method to scan? Also, are you using a Windows computer or a Mac?
01-25-2020 09:22 AM
PIXMA MX492 I am geting a message " latest formware on the server " on my message screen. how do I update my printer firmware?
01-25-2020 09:52 AM
getting Message also when trying to scan multiple pages from scanner top after the first page scanned ok, " failed to open a session on the device " whn select scan again.
This used to work all the time for me but dont know what changed and why not now......
01-25-2020 09:59 AM
getting Message when trying to scan multiple pages from scanner top after the first page scanned ok, " failed to open a session on the device " when select scan again. What is triggering this error message.
01-25-2020 10:04 AM
Yes, I selected the PDF document option. And yes I have a MAC computer
01-27-2020 03:02 PM
What version of OSX is installed on your computer?
To determien this, please click on the Apple in the upper left hand corner and then About This Mac.
01-28-2020 12:59 PM
version 10.15.2
Mac Catalina
