01-25-2024
10:58 AM
11:02 AM
Hello, I need some help with photo printing. I have a Canon MX475 and my photo print quality are poor, pale. I have Also made some test .
The top left picture is very good qualiti, I have made on a Cewe machine in DM store.
I get the closest acceptable quality when I print it as a color PDF document in normal mode. If I changed the setting photoprint Mode the quality was as bad as printed with Canon easy photo print .
I have tried to print with Microsoft photos as well but ged the same bad quality result.
Only in PDF and word format I get some better quality but in this case the print is fast and for that reason is not so good.
So the best option would be to print with canon easy print or with other software print as picture without that poor quality.
Thank you for your help!
01-25-2024 12:25 PM
I think it's going to be the case of what software will be able to handle proper color workflows. i.e. for the specific type of media/paper you're priting to, can that software use the correct profiles.
For the highest quality output, I believe you'll be best served when using dedicated software to produce photographic prints. v.s word processing software such as Word.
