03-26-2013
07:46 PM
09:27 AM
I had a paper jam on my MX432 and since then my print is blurred, shadowing, double printing.
03-29-2013 02:11 PM
Typically after a paper jam the encoder strip gets dirty. Cleaning it usually resolves this issue. Heres how to check it. If you open up the front where the paper prints, theres a clear strip that goes from left to right (its right above the greasy metal strip). If the strip is dirty (typically with ink smudges), clean with a little bit of water and q-tips. BE GENTLE! And, be sure to UNPLUG the machine before proceeding. After cleaning do a test print to confirm.
03-29-2013 12:19 PM
I had a paperjam on my MX432 all-in-one and now I am getting blurred, shadow, duplicate letter printing. I did a clean through the machine and I thought it realigned the heads and it is better however only 70%.
03-29-2013 02:11 PM
05-08-2013 04:30 PM
05-08-2013 05:01 PM
You're welcome. Glad I could help.
11-14-2013 07:35 AM
Brilliant!!!
This worked for my MG3150. I tried everything and it was the last throw of the dice. Be careful, it's quite tight in there.
Thanks. (I used a baby wipe, worked a treat).
01-23-2014 11:40 PM
Thank you. Mission accomplished! Spot on!
06-01-2014 09:14 PM
WOW!
That was too fast. Thanks alot!
They should have noted that on the troubleshooting brochure the printer comes with.
We were this close to get a new one after spending 4 hrs cleaning, testing, aligning, and wasting precious ink etc...
Anyone knows a cheapper way to refill these cartridges PG-240XL? $100/month in ink is getting ridiculous, or may be we need a more efficient printer.
- M5 Team
Custom Vape Drip Tips and Accesories
facebook.com/M5DCUSTOMS
06-30-2014 09:47 AM
09-09-2014 04:19 AM
wow it worked I just wish i would of looked up this instead of trying to get it to work by printing out several pages plus waste of ink but you are a genius thanks for posting this issue.
Thanks you saved me from purchasing another printer
