03-26-2013
07:46 PM
09:27 AM
I had a paper jam on my MX432 and since then my print is blurred, shadowing, double printing.
10-25-2014 09:08 AM
I also tried everything in the manual for blurred printing and this was the only method that worked. THANK YOU!!
12-13-2014 09:56 AM
01-05-2015 10:35 AM
thank you soooo much!! this was really useful. I was having a really panic as I was trying to print all my RAF paperwork. But these simple instructions were increadibly easy to follow and worked like a charm.
01-17-2015 07:35 AM
Can't thank you enough for this information. I have spent the best part of a day trying to work out what is wrong with the printer (which is typically just out of warranty!). Today was the last 'shot' at it as I felt I couldn't afford to spend any more time on this and my 4 month old was being neglected! Came across this website and your advice - golden. Thank you.
03-04-2015 09:20 PM
advise how you open up the "front where the paper prints." I'm assuming that is the panel on the lefthand side of the printer.
03-29-2015 08:38 PM
I'd pressed "clean" four times and "deep clean" three times - and still the same problem. I was ready to tear all my hair out. Thanks so much! Now my problem has been resolved.
07-12-2015 11:41 AM
You did it. The information helped. Thanks.
09-30-2015 05:52 PM
Brilliant, that's sorted my printer out too. Thank you
02-27-2016 10:57 AM
Thank you, this sollution fixed my printing problem too. I used isopropyl alcohol along with a dozen Q-tips. I plan to buy some doctor length Q-tips for easier access. Adding this preventative maintenance to my list to clean once a month.
04-18-2016 05:07 PM
There is an alternative to buying new cartridges each month.
1. Get some replacement ink bottles online (there's plenty to choose from - just Google it).
2. The cartridges on my MX722 have an indent on the bottom that can be punctured (carefully) and with the syringe that comes with the bottles, you then very carefully (use the gloves otherwise ink will be all over your hands);
3. After the ink is inserted in all of the cartridges (use electric tape to seal up the hole), then close the access door and wait until the beep sounds to tell you the cartridges are empty, etc.
4. Just as you hear the beep, press the stop button and keep it pressed until the error message clears the display and it says it is processing.
5. Take note that this process does not alert you to empty cartridges and you'll have to refill each cartridge (usually the blacks) is emptied. The cartridges appear as grayed-out images on the display.
I don't know if it'll work on your printer, I only know it works on mine. I save myseld at least $300 a month.
Good luck
