08-24-2013
06:46 PM
04:19 PM
My MX320 printer message says there is a document in the ADF and to press OK to clear it. There is no document in ADF. I've pressed OK and I unplugged and replugged the printer. The message is still there. I tried to copy a legal size document before this happened. How do I fix it?
09-01-2013
02:36 PM
04:22 PM
Hello newrisks,
This error typically occurs if you press the STOP button during scanning or copying. You would then press the OK button so the remaining document is automatically fed out. Please try pressing the OK button, and then STOP to see if the error clears.
If not, please click HERE for a step-by-step guide to make sure there are no paper jams in the ADF area:
If the issue persists, please reach out to our technical support team through the link below for further assistance. Thanks!
01-16-2018 12:58 PM
I have this error message and the links you provided do not open. Any other solutions?
01-16-2018 01:09 PM
Hi, fbantin!
Thanks for catching that outdated link. The post containing it was from almost five years ago and we've overhauled our site since then, causing some older links to no longer work. We've updated the post accordingly. You can check out knowledge base article on the topic right HERE and if problems persist, our support team is available HERE.
We hope this helps!
09-10-2024 04:17 PM
The article link directs to a Salesforce login. Is there an updated link?
09-10-2024 04:23 PM
We've updated the post above yet again with the current link. You'll find the article HERE.
