PIXMA MX 920 error code C000
LeslieD
This printer failed to tell me ink was out, and it printed anyway. I put in new printer cartridges, and I got error code C000.
I unplugged it and replugged it. No go. I found my way to this forum, and I saw someone post about another error to plug it into the wall instead of the power strip. Still no go.
is there anything to do?
Thank you.
2 ACCEPTED SOLUTIONS
LeslieD
So, never mind. Operator error.
i had two small black ink cartridges installed in instead of a yellow. That happened because I was installing 3 at the same time. I wish it had told me right away. It would have saved me a LOT of time and frustration.
Hello.
This particular error can occur if something is keeping the ink carriage from moving properly.  This usually happens if a tank is installed in the wrong slot or if a tank is not snapped into place properly.  If the error ever happens to occur again, please visit the following link for more information:
C000 Error
5 REPLIES 5
LeslieD
Hello.
C000 Error
Thank you.
Solved my problem thnaks
i checked my cartridges and YES...one was not seated well.
This forum was my last attempt before buying a new printer. Thank you!
