06-17-2023 11:14 AM - last edited on 06-20-2023 09:58 AM by Danny
I have downloaded the latest drivers from Canon on my PC, but it still doesn't print any text, only pictures.
If I combine text and images, it only print images. If I print an image of a text, it does print the image with text, black on white background = it looks like a text document, but if I write on a txt document / Note Pad, there is nothing on the printed paper. The funny thing is that this process started gradually, with the text starting to fade, and eventually it was gone.
06-19-2023 03:55 PM
and I forgot, I have a PIXMA MG6350, i quote myself,
If I combine text and images, it only print images. If I print an image of a text, it does print the image with text, black on white background = it looks like a text document, but if I write on a txt document / Note Pad, there is nothing on the printed paper. The funny thing is that this process started gradually, with the text starting to fade, and eventually it was gone."
06-19-2023 03:53 PM
Yes, I wrote to Canon help center, really, this must surely be a common problem and is probably some upgrade gone wrong, if not on Canon's party, it could well be some windows/general shift that has left our printers behind, And all those expensive cartridges of no use. I wish there was just someonone techsavvy that could explain what to do, cause there is probably a simple solution to this problem.
