PIXMA MG6350 Prints No Text, Only Pictures
Jseb
I have downloaded the latest drivers from Canon on my PC, but it still doesn't print any text, only pictures.
If I combine text and images, it only print images. If I print an image of a text, it does print the image with text, black on white background = it looks like a text document, but if I write on a txt document / Note Pad, there is nothing on the printed paper. The funny thing is that this process started gradually, with the text starting to fade, and eventually it was gone.
2 REPLIES 2
Jseb
and I forgot, I have a PIXMA MG6350, i quote myself,
If I combine text and images, it only print images. If I print an image of a text, it does print the image with text, black on white background = it looks like a text document, but if I write on a txt document / Note Pad, there is nothing on the printed paper. The funny thing is that this process started gradually, with the text starting to fade, and eventually it was gone."
Jseb
Yes, I wrote to Canon help center, really, this must surely be a common problem and is probably some upgrade gone wrong, if not on Canon's party, it could well be some windows/general shift that has left our printers behind, And all those expensive cartridges of no use. I wish there was just someonone techsavvy that could explain what to do, cause there is probably a simple solution to this problem.
