07-22-2026
12:47 AM
08:09 AM
Pixma 3620/OS is Windows 11
Setup is complete. I have a blue light indicating Wi-Fi connection.
Printer will not respond. Error message says "estimated ink levels". This is brand new printer with brand new Canon Brand ink installed. I've had this model before and have never had this issue. Any thoughts on what's happening here?
07-22-2026 05:08 AM - edited 07-22-2026 05:37 AM
I assume that your printer is an MG3620, a good printer I own one as well.
First make sure the cartridges are locked in properly. Normally the printer flashes an orange light if there is a problem with the cartridges themselves.
This estimate ink levels message indicates that the printer cannot see the ink levels. Usually this is a sign the full driver package has not been installed. All the software can be found here: https://www.usa.canon.com/support/p/pixma-mg3620 download the full driver and software package and install it.
Here is a guide (the video is a bit basic but I watch it when I installed mine) written instructions to connect to a Windows pc is just below the video. The setup connects your printer to your PC and the PC connects it to your wifi. I connected my MG3620 using a printer cable, and setup network printer sharing so other devices can print.
https://support.usa.canon.com/kb/s/article/ART162917
07-22-2026 08:49 PM
Thank your Derrick. I'm able to print now but only if the USB cable is connected and the ink levels show up. If I try to print through the Wi-Fi connection I get that same error message that ink levels cannot be determined. While I can now print not being able to do it via the Wi-Fi is a PIA. If I try to use the Diagnose and Repair it tells me it can't identify the printer. How can it identify it in all other ways but that one?
I've had this same printer before and it was giving me problems with printing and the paper feed kept getting jammed. This new one is a replacement for that one. The other was working fine when connected via the Wi-Fi so why is this one not accepting a print command when wireless? I did use the USB cable to run the setup because the router is in another room several feet away and one of the instructions wanted me to perform some action with the router I didn't quite understand.
Paul L.
