01-23-2025
03:15 PM
03:24 PM
01-27-2025 02:27 PM
Hi Deons51,
The 5 blinks error is an indication that your printer does not recognize one or both of the ink cartridges in your PIXMA MG3620.
Please make sure that you are using Canon ink cartridges. You can try using third party ink , but those cartridges have not been tested and we cannot guarantee they will work properly.
Also, please make sure that you have both the black ink cartridge and color ink cartridge installed in your printer. You will get this error if one or both ink cartridges are not inserted.
Please also make sure that you are using cartridges that are compatible with your PIXMA MG3620. The following ink cartridges can be used with your printer:
PG-240
PG-240XL
PG-240XXL
CL-241
CL-214XL
Ink for your PIXMA MG3620 can be purchased directly from Canon using this link:
https://www.usa.canon.com/shop/ink-paper-toner/finder/pixma-mg3620
01-27-2025 03:28 PM
You're welcome to use whichever ink cartridges you like.
All we're saying is our inks are formulated specifically for our printers and printheads, so you won't have any issues with the printer not recognizing the cartridges.
01-23-2025 03:20 PM
Welcome to the forum!
So that the Community can help you better, let us know what model printer. Which version of Windows or macOS you are using? How are you connecting? Exact error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
01-23-2025 03:21 PM
Also, turned off printer for 10 minutes, pressed the button 5 times, why is it still not working?
01-23-2025 03:23 PM
MG3620 The printer was working, but an out of ink, so I replaced the cartridges. Now I'm getting flashing yellow lights, 5 times, then a pause. I don't think it matters about my version of Windows because it was printing before I ran out of ink
01-23-2025 03:25 PM
Also, I checked the ink cartridges and wiped off the bottom where the ink comes out. I'm getting black fingers so I know the cartridges have ink
01-27-2025 02:27 PM
Hi Deons51,
PG-240
PG-240XL
PG-240XXL
CL-241
CL-214XL
01-27-2025 02:44 PM
To help us use only Canon Ink Cartridges, please make them more affordable. I would gladly buy the name brand, but they are too expensive. Sad profit over reliability is Canon's answer to this problem.
01-27-2025 03:28 PM
