PIXMA G7020 clogged ink lines
bhemmer82
The ink lines on my PIXMA G7020 appear to be clogged.  I try an ink flush and the ink well on the black never goes down.  It also looks like the ink line is not filled with ink.  Some of the color ink lines are not filled with ink either.
Is there a way to get ink flowing through the lines again.
3 REPLIES 3
Moderator
Moderator
Hi, bhemmer82!  One of your peers recently posted about a similar problem with the same printer model.  Check out that thread HERE.
Review this document and following its steps.  If this does not work, I would recommend contacting Canon Support.
Canon : Inkjet Manuals : G7000 series : Ink Does Not Come Out
Register your product.  You will be provided support options.
Canon Support for | Canon U.S.A., Inc.
1 (800) 652-2666
I has seen that post and had already tried all that multiple times.  It did not resolve my issue.
