PIXMA G7020 Printer - Unable to pick paper tray
Helpless24
There is no option to make the bottom paper the the default. Sometimes it switches to rear paper load and I have to turn it off and on many times. There is nothing in the settings that allows you to select the default source.
4 REPLIES 4
DerrickL
I have a Mac and I never see a screen with the options shown (Windows OS). Really frustrating to waste my time turning the printer off and on! Canon needs to fix it.
Hi.
If you have a Mac, and you're not seeing options to change your paper, that typically means you're using Apple's AirPrint drivers rather than ours. You can fix this by following the installation procedure at https://canon.us/g7020setup
I installed it but I still don't have an option for paper source
