12-19-2025
05:15 PM
05:24 PM
Tiffany
Printing a document in color today worked fine for a dozen pages, and then the first bad page started fine but by the end of page only magenta was printing. With more attempts only yellow printed and finally nothing, A nozzle check showed black was fine but all colors were nearly invisible. I tried CLEAN and then DEEP CLEAN and finally INK FLUSH with no change. I tried printing text in B/W and that also showed nothing despite the nozzle check still showing black (only). I removed the color print head and flushed it with warm water but no change. The ink lines are filled with ink but it seems there is no flow. I would be glad to replace the print head if I thought it would fix the problem but I doubt it.
12-20-2025 04:30 PM - edited 12-20-2025 04:37 PM
You may need to perform and ink flush to clear the ink lines and refill them:
The ink flush process is designed to clear clogged print heads and restore print quality. It uses a significant amount of ink, so it should only be performed when necessary.
After the Ink Flush:
Check Print Quality
After completing the flush, print a nozzle check pattern to see if the print quality has improved.
Repeat if Necessary
If the print quality does not improve, you may need to perform the flush again after waiting 24 hours.
