09-06-2024
07:41 PM
09:53 PM
Tiffany
Need help to print graph paper which is default in to settings. Also, not sure what 2 circle intertwine swith is on the panel under QR switch. ?? if some one can help me
09-17-2024 03:55 PM
Hi parthutejani100,
To print graph paper with your PIXMA G3270, please follow these steps:
1. Press the Home button on your G3270 one time.
2. Repeatedly press the down arrow to select Settings and press OK.
3. Repeatedly press the down arrow to select Template print and press OK.
4. Repeatedly press the down arrow to select "Graph 1", "Graph 2" or "Graph 3" and press OK.
5. If you wish to specify the number of copies or the paper settings, those can be changed on the screen that appears.
To print your graph paper, press the Start button labeled Color.
More information regarding printing templates can be viewed in the manual using this link:
https://ij.manual.canon/ij/webmanual/Manual/All/G3070%20series/EN/UG/ug-035.html
To view the information regarding each component of your PIXMA G3270, including the Wireless connect button, please use this link:
https://ij.manual.canon/ij/webmanual/Manual/All/G3070%20series/EN/UG/ug-160.html
