03-16-2024
03:47 PM
03:50 PM
Hi, I need some help. I cannot find or locate the ethernet connection on the back of this printer.
There is a USB "U" shaped port there at the back left side. Under that is the power
cord plug in. Thats all I can find. How do I plug in an ethernet cable?
03-16-2024 03:52 PM
Thanks for joining the conversation, guitarplayer23! The PIXMA G3270 talks to other devices via Wi-Fi and via a USB cable. This model does not support Ethernet connectivity and that's why it doesn't have an Ethernet port.
Hope this information helps!
03-16-2024 05:38 PM
Thanks Danny. Man I wish I`d have known that before purchase. I have no router
and the WiFi won`t connect. I am able to copy with the USB.
03-16-2024 06:40 PM
Is there an adapter that I can use with the USB that will accept the Ethernet cable?
03-17-2024 09:01 AM
The wifi will not accept either. is there a secret to this?
03-17-2024 09:34 AM
You can connect the printer to your computer with a USB A to B cable. Like this:
OR, you can connect the printer to your wireless router using WiFi. Tap HERE for instructions.
03-17-2024 10:03 AM
I guess w/o a wireless router it will not connect?
03-17-2024 10:09 AM
You can use the USB cable to connect it directly to your computer.
I suggest contacting support so they can walk you through the set up process one-on-one. They're available Monday through Friday from 8am to 8pm (ET), at 1-800-OK-CANON (800-652-2666).
03-17-2024 10:12 AM
Thanks, yes I have done that. I wanted wireless. Oh well I bought the wrong copier.
03-17-2024 02:28 PM
Whats a good inexpensive home router that will work with this copier.
thanks for the help!!!
