08-05-2014 10:04 AM
MG5320 going through the motions of printing, but there is no image on the page.
It smacks of a clogged nozzle, but should I be messing with that? Ink levels are fine, and it spans multiple functions (i.e. Scanning, copying, printing). PC says OK, but I have yet to figure out the invisible ink thing (a small joke).
Ideas?
Mike
08-07-2014 03:05 PM
Hi MCoccia,
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-226BK
CLI-226M
CLI-226C
PGI-225PGBK
CLI-226Y
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5320 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that is at the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly?
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
08-07-2014 03:33 PM
Patrick:
Excellent advice...except it did not work. Unfortunately, I am at the age where I cannot be bothered with multiple attempts at fixing this thing. Always had good luck with Canon...hope my camera performs better than my printer did after a year.
Thanks anyway.
Mike
