My mx 452 isn't printing
dlb1944
it goes through all the motions as if it is printing however the page is blank I've cleaned ink heads with no success. Any thoughts or fixes for this situation ?
1 REPLY 1
Patrick
Hi dlb1944,
First, a test should be performed of your PIXMA MX452.  The Nozzle Check pattern shows if each print head nozzle is operating properly.  Please perform the following steps to print a Nozzle Check pattern:
 1.  Load letter-sized, plain paper in the rear Tray.
 2.  Press the SETUP button on your PIXMA MX452.
 3.  Press the left or right button until [MAINTENANCE] is displayed in the LCD, and then press OK.
 4.  Press the left or right button until [Nozzle check] is displayed in the LCD, and then press OK.  The nozzle check pattern is printed.  Please compare your printout to the example that has been attached to the bottom of this post.
If the page prints incorrectly, printhead cleanings should be performed.  Please follow the instructions below to clean the printhead:
 1.  Press the SETUP button.
 2.  Press the left or right button until [MAINTENANCE] is displayed in the LCD, and then press OK.
 3.  Press the left or right button until [CLEANING] is displayed in the LCD, and then press OK.
After 3 or 4 cleanings, print another test page.
Does the test page print correctly?
Friends and Family
