04-19-2013 09:45 PM
My PIXMA610 Series Printer will not turn on. Doesn't seem to be getting power.
It worked fine yesterday but today when I went to turn it on I found the unit unplugged. After reinserting the plug it would not turn on. Live alone with no pets. Strange.
Any ideas? Is there a reset button?
04-19-2013 09:46 PM
Priniter is a PIXMA MP610 series
04-21-2013 08:43 PM
Hello jeharter.
To try and resolve this issue, please unplug the power from the unit for about 25-30 minutes. Once this time frame has passed, plug the unit in directly to a wall outlet to see if the printer will power on.
Unfortunately, if the issue persists, please contact our support group using the link below for additional assistance with this issue.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
04-21-2013 08:54 PM
Thank you for your help. The printer did respond after unplugging the cord for an hour. Unfortunately it is now giving me an error message that the print head is not correct and to install the correct print head.
Any ideas how to reset this?
Thank you
Jim
04-21-2013 09:44 PM
Hi jeharter,
I would recommend trying to remove and reseat the print head to try and resolve the issue. Use the following steps to reseat the print head:
Push the tab (A) and lift the ink tank to remove.
Do not touch the Print Head Lock Lever (B).
04-24-2013 07:37 PM
Did as you advised but the error code U052 came up again - the type of print head is incorrect. Install the correct print head.
Do you have any additional thoughts?
Jim Harter
04-24-2013 08:01 PM
Hi jeharter!
Unfortunately no, you have performed all of the troubleshooting that we would have you do. Your printer would require service options to have this corrected. Please contact us by e-mailing mfp@cits.canon.com or by calling 8by calling 800-828-4040 between 10AM and 10PM EST Monday through Friday to hear your service options.
I am sorry for any inconvenience this causes.
04-25-2013 06:51 PM
Thank you I will contact them presently.
Jim
