04-21-2014 01:58 PM
Canon MX 890 makes all the appropriate noises like it IS printing. Ink cartitridges are sufficiently full. I checked another forum question and verified my IP address that the LAN connection and strength is 59% and 62% respectfully. I was unable to verify the gateway (?) address as I do not have the user name or password.
04-21-2014 03:25 PM
Hi, jtparkey!
So that the Community can help you better, we will need to know the version of Windows or Mac in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
04-21-2014 05:08 PM
Windows 7 Home Premium
05-05-2014 11:26 AM
Hi jtparkey,
I would ilke to have you print a nozzle check pattern from the printer to see if the inkjet nozzles are dispensing the ink correctly. To do this, please follow the steps located at the link below:
Printing the Nozzle Check Pattern
Did the nozzle check pattern print correctly, including the black grid that appears above the colors?
If this is a time-sensitive matter, additional support options are available at Contact Us.
09-06-2014 11:14 AM
I have done all this and it still will not print. it sounds like it is doing everything right, but thr page is blank.
09-24-2014 01:48 PM
Hi stets4,
Because performing cleanings did not get your PIXMA MX892 to print, it may require service.
Please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
