08-23-2026 09:25 AM
I have done Clean Ink Heads, Deep Clean Ink Heads (multiply times on both!), Clean roller and Clean Plate and I'm still getting while lines through colored print about 1/2 apart down the entire page. How do I fix this?
08-23-2026 05:37 PM
Perform a manual head alignment, here are the instructions.
08-23-2026 10:25 PM
Derriek,
I did what you suggested and it didn't work. Any other suggestions, please.
08-24-2026 10:22 AM - edited 08-24-2026 10:29 AM
The only other thing is to perform an auto alignment, sometimes it does better than the manual one. If that does clear the white lines, then a print head replacement may be your best bet. It is not expensive. It is available from Canon Shop: https://www.usa.canon.com/shop/p/ch-g2-color-print-head?msclkid=05790e7bc97517188d2c64f79c4d886b&gcl...
08-24-2026 12:49 PM
I meant to say, if the auto alignment does NOT clear the white lines a print head replacement is your best bet.
