Mac PIXMA TR8620 scanner not found, cannot communicate error (solved)
gateslinger
All-
So I've been wrestling with this issue of the scanner not being found by the IJ Scan Utility Lite under Mac Catalina 10.15.7 where it wasn't finding the scanner and throwing the pop-up error:
  Cannot communicate with scanner.  Possible reasons:...
I could print fine but could not scan.  Printer was installed with Setup from the support page and added using Airprint Secure, but could not be found by IJ Scan Utility Lite.  However my Windows box finds the scanner portion of the printer fine.  I finally broke down and called support and I got it working.  Specifically, IPv6 needs to be turned off on the printer.  To do this:
  • On the printer, go the printer home screen
  • Click on the Device settings wheel
  • Click on Device Settings
  • Click on LAN Settings
  • Wi-Fi
  • Then click on the "Advanced" tab
  • TCP/IP settings
  • IPv6 - it'll throw a pop-up message, click Yes
  • Enable/disable IPv6
  • Click Disable
  • Exit back to Home
And you're good to go.  Hopefully this will save some frustration and time for others.
-G
3 REPLIES 3
skahn
thank you. this did not work for me. anyone else? i just bought this printer. installed all the drivers etc. still does not recognize my computer for scanning.
skahn
in fact for some reason that just disabled the wifi on the printer. help!
bruce334
Followed your directions and went back to Home screen. IJ Scan Utility still gives message unable to connect or find scanner. Printer and Scanner in Settings shows printer, however when trying to open scanner, no scanner appears. After being on the phone with Apple for an hour they are positive it's not a Mac problem!
Holiday
