MX922 scanner problem message: set the pc to start scanning
Denise
I am trying to scan using my MX922 printer.  I am getting a message: "set the pc to start scanning." Can't find what this means.
88 REPLIES 88
Hi Skormy -- I don't have a Mac so I can't help you, but hopefully someone else chimes in.  Perhaps a re-install from the original CD would make the difference, if no one has any better ideas.
As a follow-up, I did wind up re-installing the software and everything seems to work.  It was pretty the last thing I could think of to do.
Glad it worked for you. 🙂
Thank you so much for solving my stupid problem. I tried getting the solution from Canon and of course, no such luck. You have been a bit of a life-saver for me! many, ma!ny kudos to you
kawender
I am having this problem all of a sudden too, and I have a time-sensitive document to scan. I am running windows 10.
press save/forward
Don't know why I didn't try that earlier, but it worked. Thank you!
Thanks, this worked perfectly for me! I had the exact same issue, running Win7, and this fixxed it.
Thanks, dddderek - I did this and it worked!  When I pressed SAVE/FORWARD on the MX925 it could see my Mac again.  Thanks again.
Oceans of thanks Varice.
After more than one year of working operating panel, I got a "set your PC" message all of a sudden. I checked and found out that the PIXMA was detecting my laptop (with its specific name) and able to communicate with it (receiving the scan orders and delivering the scanned PDF) on wireless. I tried to search my LAN again to detect the error and suddenly the printer did not detect my laptop any longer while kept communicating with it !!
I followed your steps. The only things I needed to do after that were:
1. Restarting the printer, and
2. Checking my laptop was detected (with Save/forward button): it was there once more!
3. The operating panel backed to work again.
It is frustrating that Canon could not address the issue properly and sticked to its nonsense solutions (asking to read the instructions, repeating the very obvious instructions etc). They apparently do not listen to people. Many thanks for your wonderful solution, buddy.
