06-20-2015 09:23 AM
The front door on my MX922 won't stay closed. I removed it to try and see what's going on. There is a small white 'lever' near the left hinge. But it seems to be loose. I don't see how it can hold the door closed. Is there some other way it's supposed to stay closed?
Thanks.
06-20-2015 11:19 AM
Resolved it myself. There is a spring on the inside of the front cover that helps the tray extender pop out. I had the spring in wrong and apparently that keeps the door closed.
08-21-2015 03:25 PM
Hello, do you remember which way you put the spring? We had an accident with the door and I've got all the pieces back in place, but I can't figure out the spring. Thank you!
08-21-2015 03:40 PM
I wish I had taken a picture of it for you. But it took some time for me to figure out how it went back in. I remember it was the opposite of what I thought it should be, hence my post. I also remember it wasn't easy to get it back together with everything in place. Sorry, not much help!
08-21-2015 08:20 PM
No problem, thanks anyway!
10-25-2016 05:02 PM
Here's a picture of the spring setup. Let me know if you need any other info... I have a spare door that I've taken apart.
01-22-2017 02:26 PM
How did you remove the door and open it up? I am having a silimar problem with my Pixma MG5420
06-20-2017 08:53 AM
How do you remove the front door to fix the spring. Door won't stay shut and paper holder doesn't come out.
06-20-2017 10:23 AM
Hi gwaeloduser,
Based on the specfic issue described, It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
06-20-2017 10:36 AM
I think we have sorted it. My husband has had it apart and it seems to be working now. Thanks.
