08-15-2014 09:38 AM
Whenever I scan using my MX922 with the document feeder on top, the final scanned page is crooked within the document. That is, everything on the page is about 10 degrees off horizontal, including the visible bottom edge of the scanned document. Is there anything that can be done to realign the paper feed to produce straighter scans?
08-25-2014 03:35 PM
Hi mikebkatz,
There is a setting in the IJ Scan Utility that can be disabled that will resolve this issue. Please follow these steps:
1. From the Start menu, click All Programs, Canon Utilities, IJ Scan Utility and then click on the IJ Scan Utility to start IJ Scan Utility.
2. Click on Settings.
3. On the left hand side, click on Document Scan.
4. In the Scan Options section, click the [+] next to Image Processing Settings.
5. Disable "Detect the orientation of text document and rotate image".
6. Click OK.
Once set, please attempt to scan.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
09-22-2014 06:42 PM
10-13-2014 08:51 AM
Hi zooks64,
What program are you currently using to scan? Also, do you experience the same issue if you make a photocopy of a document when using the top feeder (ADF) of the printer?
If this is a time-sensitive matter, additional support options are available at Contact Us.
10-13-2014 10:21 AM
Normally I just stick a thumb drive directly into the print and scan to that.
No, making a copy from the feeder did not result in crooked copies. I check to make sure the feeder wasn't feeding crookedly.
I broke down and installed the software and found a setting that fixed the issue but it wasn't the way you described in a previous post. I don't know if they software has changed since then but mine didn't look exactly like the description you gave before.
Regardless, I have resolved the issue - at least for scannign to my computer. However, I would like to know if there's a way to set that on the printer for others who will wnat to scan directly to a thumb drive and not to a computer.
10-13-2015 10:56 AM
I am having this problem as well. Like zooks said I don't know if the software has updated since the original canon employee posted. But there isn't a "Detect the orientation of text document and rotate image" to disable.
Is it now, "Correct slanted text document." ? I have that checked currently.
10-15-2015 10:45 AM
Hello.
The "Correct Slanted Document" option is the correct option for newer installations.
If you continue to have difficulties, please contact our support group using the "Contact Us" link below for additional assistance.
