02-12-2016 04:56 PM
I haven done EVERYTHING to fix the blurry text from cleaning, deep cleaning, alignment, even doing this https://support.usa.canon.com/kb/index?page=content&id=ART142447 I feel like I'm about to go crazy. I don't know how to fix it. Its only the black. I've tried changing the ink as well with the same issue. Anything else?
02-15-2016 05:20 PM
Hi Ameriguat,
In order to better assist you, allow me to ask a couple questions:
Is text also blurry when you make a photocopy?
What is written on the label of the PGBK cartridge?
Which version of Macintosh or Windows are you using?
I look forward to your reply.
02-21-2016 10:32 AM
sorry I was out of town so I couldn't check...
yes, it is blurry even with photocopy
C250
Windows 8
02-21-2016 10:37 AM
02-22-2016 03:58 PM
My Canon Pixma MG6320 has been doing the same thing for the past 4-5 months, essentially rendering it a giant paperweight. I guess printers only last <2 years nowadays. I have cleaned the encoder strip multiple times and I have cleaned the print cartridge and still nothing. I have also replaced the ink twice and done all the calibrations that are available throught the printer's menu and I still get the same result.
I am both glad and saddened to see that I am not the only person experiencing these problems. What is the problem, and what is the fix?! This can't be an isolated problem.
02-22-2016 08:54 PM
02-23-2016 06:19 AM
Hi mg6320BLURRY,
When the text and images printing from the printer are blurry, and Canon genuine ink tanks are already being used in the unit, we recommend performing at least one cleaning and two deep cleanings on the unit, performing a print head alignment, and cleaning the encoder film of the printer to try and resolve the issue. If these recommendations have been performed and the issue has not been remedied, the printer will need to be serviced to determine the source of and resolution to the issue. We ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) to obtain your servicing options. There is no charge for this call.
02-23-2016 09:09 AM
Yes, I have completed all the cleanings, print head alignments and encoder film cleanings and I am still getting the same blurry text in the black ink. Every other color looks fine and prints as it should. The example Amerigaut gave above is the exact problem I am having. Colors print fine, but when it comes to black ink and text, it is blurry.
Because this is now a discontinued printer selling for around $100 on Amazon (I paid $70 in December 2013), the cost of getting it serviced is not worth it. Bench fees to take a look at the problem will probably range from $50-70 plus whatever parts need to be replaced, effectively rendering all the time and money I've spent on extra ink (official Canon ink running around $60 for a replacement set) and the printer itself a giant waste.
I will never purchase another Canon printer again. When it worked, it worked wonderfully, but as soon as a problem manifisted itself, the only solution given is to throw more money at it. This is a perfect example of planned obsolescence in our modern throwaway culture. What a waste.
01-09-2018 09:15 PM
01-27-2018 09:32 AM
Today I've replaced the PGI cartridge (original one from Amazon), but the issue remains.
