09-07-2013 11:01 AM
My printer has been working just fine. However, just today one of the cartridges was low, so I replaced it. Now when I try to print it just spits out blank pages. I ran the test to check for clogged nozzles, but the all blocks print beautifully. What do I try next?
09-06-2017 03:01 PM
Haven't found a soulution yet ?
no
11-23-2017 11:10 PM
The solution that worked for me (easy)
Open ink well, remove cartridges.
Take can of compressed air, spray DIRECTLY into the...nozzel ports? Not sure what they are called. The part that contacts the cartridge where the ink comes out. It will spray the ink residue a bit but I don't think it harms anything. My printer is about a year old that there's ink spatter all inside already.
Anyways, it worked for me.
Before I used the air I had the blank pages problem and a nozzel check patter was a little crooked. Anyways, I did another nozzel check pattern, printed fine, and did a test page in all my document programs and the all worked.
Hope this helps and use at your own risk.
12-11-2017 02:01 PM
it's the printer paper type. under device settings -> paper settings set the paper to plain paper, rather than matte, glossy, etc. It's the first option, all the way to the left. This will fix your problem.
03-05-2018 07:26 PM
I have seen this problem with many of the Canon 5 cartridge inkjet printer models. The symptom is that the printer suddenly stops printing ink onto the page even though the cartridges all contain ink and the print-head is not blocked. By suddenly, I mean one printjob prints perfect and the next is totally blank. Printing out a nozzle test also results in a completely blank page.
This appears to be a software issue and I have rectified this many times on multiple printers using the following method to "reboot" the software after clearing the internal memory. Note this does NOT apply if printhead is blocked with dried ink!
Note that steps 5-8 are not always necessary but it does force the printer to go through additional boot-up sequence and seems to be neccessary sometimes.
Good luck!
11-04-2018 10:16 PM
11-04-2018 10:21 PM
11-04-2018 10:44 PM
11-04-2018 10:48 PM
You need to read the full thread. This solution is for when the printhead is ok and not worn out but the software just needs to be re-booted. Of course if you are wealthy and want to send extra profits to Canon before necessary then ok...
11-04-2018 10:49 PM
11-04-2018 10:54 PM - edited 11-04-2018 10:55 PM
Sorry I have worked with printers before I'm an electronic engineer and I know after all these solutions then the only one option left on the table is to replace the print head. You do not have to be wealthy to order a print head! This is the way the manufactures make their money Print cartridges and print heads no 1 and 2.
