10-23-2016 08:47 AM
My MX860 won't power up. Worked a few days ago. Replaced for now, but would really like to get fixed. The printer cost over $200, so I really would welcome any help on getting it working again. Thanks......
10-25-2016 10:07 AM
Hi ninamclain2002,
Please follow these steps to resolve this issue:
1. Please confirm other devices plugged into the electrical outlet power on. At this time, please do not disconnect the printer at the electrical outlet. If there is an empty electrical slot, plug in a lamp to make sure the outlet is working.
2. Disconnect the power cord completely at the back of the printer.
3. Please push the power cord back into the receptacle ensuring that the cord is pushed in as far as it will go.
4. Pull the cord and see if it easily slips out from the connector or if it seems secure.
5. If the machine does not power on automatically, press the ON/OFF button.
6. If the machine does not power on after the power cord was pushed in all the way at the back of the printer and the ON/OFF button was pressed, please unplug the power cord from the machine and leave it unplugged for no less than 20 minutes.
7. Please then reconnect the power cord, ensuring that the cord is pushed in as far as it will go.
8. Press the ON/OFF button.
If your PIXMA MX860 does not power on, it is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
10-31-2016 09:45 AM
Thanks for the feedback. I will do what you told me to do, and see what happens.
04-19-2017 02:59 PM
POWER TO PRINTER GOOD, REPLACED POWER SUPPLY, CANON SUPPORT HAS NO CLUE TO THE PROBLEM.
ANYONE ELSE HAVE THE SAME PROBLEM??
04-19-2017 03:17 PM
04-19-2017 03:31 PM
Hello.
If the power issues continue to persist, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
04-19-2017 03:53 PM
I have been down that road already. the answer i received was replace the printer!!
A lot of help thar was!!
04-19-2017 11:01 PM
I was told the same thing too. I like Canon, but I am thinking of trying another brand. One that stands behind their products, and doesn't just try to get you to buy a new item.
04-21-2017 12:56 PM
AS I HAVE SAID TO YOU BEFORE, YOU SEEM TO KNOW LESS ABOUT YOUR PRODUCT THAN I DO!! ANYONE CAN EASILT SAY IF DOES NOT WORK REPLACE IT. i EXPECTED MORE FROM A SUPPOSEDLY KNOWLEDGABLE CANON TECHINITION.
SO THANKS FOR NOTHING, JAMES WOOD
04-24-2017 04:48 PM
