MX522: Is it possible to print from a USB drive?
me2u
i thought I did this before.  I stuck the USB drive in with the documents that needed to be printed (nothing else on the drive) and tried to scan and print it.  Either it can't do it or I didn't understand the menu.
4 REPLIES 4
James_C
Moderator
Moderator
Hi me2u,
Yes, the MX522 will print from a USB flash drive.  What are you printing?  Note:  Only JPEGS and PDF's are supported when printing from a USB flash drive.  Please see the following link for additional details:
http://ugp01.c-ij.com/ij/webmanual/Manual/W/MX520%20series/EN/UG/UG_MemoryCard2100.html
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
Thank you so much.  Hopefully this will help others.  Printing off a USB stick offers so much convenience.
The directions say to go to Advanced Print, then select Print from USB.  Problem is Print with USB isn't displayed on my MX522.  So I can't go further.
Hi me2u,
Based on what you describe, It is recommended that you contact one of Canon's Technical Support Representatives at this point. To contact a Technical Support Representative, please use the link below:
Holiday
