03-24-2020 10:01 PM
My scanner's photo option is duplicating (2x) every time I use the photo option to save a jpg. I only need one scan saved! Autoscan and document scan are fine. They only save one scan. Anyone know what causes this?
03-27-2020 06:30 PM
Hi nanran1955.
Which scanning software are you using? If you're scanning through My Image Garden, then the scans do not need to be saved after scanning, unless they are edited after they appear. The scans are automatically saved as part of the scanning process, and manually selecting "Save" afterwards creates the duplicate.
03-25-2020 09:14 AM
Hello!
So that the Community can help you better, we will need to know about any error messages you're seeing, and the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or WiFi).
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
03-25-2020 02:02 PM
No error messages. Operating on Windows 10. Printer/scanner is 5 years old. Talked to the Canon rep and he'd never seen this problem before and couldn't help. Thought it might have something to do with Windows not the scanner.
03-27-2020 06:30 PM
Hi nanran1955.
03-28-2020 10:04 AM
Thank you so much. This worked!
