01-25-2017 03:32 PM
Hello,
I have an MX450. I recently bought a new laptop and installed the printer and when I test print a page it proceeds to take a sheeet of paper about half way in and then stops and says error 1003 load paper. I remove the paper and try again with the same results. I have uninstalled it and reinstalled it with the same results.
Does anyone have a solution for this.
Candace
01-25-2017 03:42 PM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
01-25-2017 06:56 PM
Thank you for responding. I contacted technical support and they were not able to help. They suggested getting it repaired or buying a new printer.
09-16-2017 02:53 PM
Are you having any luck resolving this issue? Mine just started doing the same thing!
01-05-2018 06:20 AM
canon error 1003 solution
Press the HOME button, select Setup, Device settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select Setup, Device settings, and then select cassette incorrect paper detection to No
this will solver error 1003
