MX450 states load paper when there is already paper loaded.
cshofstall
Hello,
I have an MX450.  I recently bought a new laptop and installed the printer and when I test print a page it proceeds to take a sheeet of paper about half way in and then stops and says error 1003 load paper.  I remove the paper and try again with the same results.  I have uninstalled it and reinstalled it with the same results.
Does anyone have a solution for this.
Candace
4 REPLIES 4
Michael
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Thank you for responding.  I contacted technical support and they were not able to help.  They suggested getting it repaired or buying a new printer.
Brynn
Are you having any luck resolving this issue? Mine just started doing the same thing!
canon error 1003 solution
Press the HOME button, select SetupDevice settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select SetupDevice settings, and then select cassette incorrect paper detection to No
this will solver error 1003
