04-13-2014 02:46 PM
How do I complete the head alignment with MX922 as the specialty paper supplied does not fit?
04-24-2014 06:55 PM
Hi cumphries,
There are two paper trays to load paper in the PIXMA MX922; the upper and lower cassette trays. The MP-101 paper should be loaded in the lower cassette of the printer as shown below:
Slide the paper guide (A) in front and (B) on the right to open the guides. Load the paper stack WITH THE PRINT SIDE FACING DOWN (3), and place it in the center of the lower cassette.
Note:
Hope this helps!
09-17-2014 12:14 PM
I have the same problem. The slider A does not slide wide enough out ot load the paper. I'm trying to use the papaere that came with the printer that should be used to do the print head alignment. I cannot imagine I'm the only one who has this issue.
01-12-2016 01:58 PM - edited 01-12-2016 02:09 PM
I have been able to get the paper loaded correctly, however, the alignment process fail every time I try it. The paper passes through and comes out blank. What can I do to fix this?
09-19-2017 12:55 PM
@Hettenkofer wrote:I have the same problem. The slider A does not slide wide enough out ot load the paper. I'm trying to use the papaere that came with the printer that should be used to do the print head alignment. I cannot imagine I'm the only one who has this issue.
i HAVE THE SAME PROBLEM IS THERE AN ANSWER
