01-09-2016 12:22 PM
Canon MG7120 Print/Scan/Fax, Windows 7/64 all updates
Wired network 192.168.1.137, 255.255.255.000, IPv4 only, port CNBJNP_D8492F1F71BF
Canon installation program “win-mg7100-1_1-ucd.exe”
Worked fine for several months. Now displays error message in lower right corner of Windows screen “Printer not responding.” Sometimes error code 5,157,69.
Completely removed all Canon programs, deleted left-over files, re-booted computer, re-installed from fresh copy of Canon installation program. It printed a test page, and then reverted to “Printer not responding.”
Read several suggested fixes on line. One owner said clean the transparent film strip (timing strip?). Did so, and it printed once before reverting to “Printer not responding.”
One person said disable IPv6. Did so, no change. One said disable Wired LAN DRX. Did so, no change.
Canon IJ Network Tool said “A port is not installed. Install a port.”
Moved to another Win7/64 computer. Same installation program, same network setup, same behavior.
What can I do to get this printer to behave? Thank you.
01-13-2016 10:27 AM
Michael, thank you for your reply.
I am going to decline your offer of telephone support. They would have nothing to say beyond what we have already tried.
Instead I used Windows Restore to roll my system back a few weeks, and it appears that this also restored the earlier drivers for the printer. The DLL files are dated in 2013.
There is no more point in trying the newer drivers, since I had no issues with the the earlier ones.
01-12-2016 09:48 PM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
01-13-2016 10:27 AM
