10-31-2020 11:00 PM
My MG6320 starting getting a message that says, 'Printer is being Used by Another Computer' and won't print untill I turn off and on the print spooler. But it only helps for 1 time. I have to go through the process again every time I go to print something. Any suggestions about a permanent fix.
11-02-2020 08:07 AM - edited 11-02-2020 08:09 AM
Please see the following thread. Some of my suggestions here might apply to your situation:
Reply here with your observations and findings.
Knowing what operating system you are using, and how/what your printer is connected to might also be halpful.
11-02-2020 12:13 PM
Using Windows 10 Home 64 bit version 1909 that came with the HP-24 all in one. Using WSD-8 port.
Not sure about static or reserved IP 192.168.0.137:80
Print spooler is running. Just replaced the PGI 250 print cartridge and it still has not adjusted the level to show full.
Below is a screen print of the message Im getting.
12-02-2020 04:06 PM
Hi encskir,
Please update your operating system to the latest release of Windows 10. Microsoft acknowledged an issue with the print spooler in version 1909 and was resolved with the next release.
