05-19-2020 09:27 PM
It gives support code 2110 "The size or type of the paper loaded is differrent from the print settings." But it says it is set to Letter and that is the size paper I have in the cassette.
05-20-2020 10:58 AM - edited 05-20-2020 10:59 AM
Somewhere in your printer driver or printer settings (application you are printing from) the size of the media is set differently than what you have loaded in the tray.
05-20-2020 07:53 PM
The printer prints fine from my computer. But I can't make copies. It says the printer setting is letter and that is what I have in the cassette - letter size paper.
05-20-2020 08:12 PM
Thanks. I went back over the instructions step by step and finally found where after I pull the tray out and put it back in it gives me the opportunity to change the paper setting. If you don't do it pretty quickly it goes away. Got it fixed now.
05-20-2020 11:17 PM
I'm glad it helped, and appreciate your feedback.
