12-27-2018 11:12 AM
My MG5422 will print the letterhead but not the text of a letter I send it from my laptop. If I email the letter to myself and click print without going through Word it prints everything. If I download it to Word it will, again, only print the letterhead.
12-27-2018 01:06 PM
Hello.
A test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5420 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to this message.
If the PGBK black grid pattern appears at the top, check to see if the lines appear as shown in "A" or if they are broken up as shown in "B". If the grid is broken up or missing, cleanings may be needed.
To perform cleanings, please follow these steps:
1. Press <HOME>.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
12-27-2018 01:06 PM
Hello.
1. Press <HOME>.
1. Press <HOME>.
12-27-2018 01:13 PM
12-28-2018 10:04 AM
12-29-2018 10:41 AM
As I said in message 4, the nozzle test did NOT SOLVE the problem. I'm still waiting for more help but they decided the test took care of it and haven't answered me again. Canon has decided my model is at its end of life and won't help me over the phone. Really!?!?
