03-18-2017 12:19 PM
Just installed new PIXMA MG3620; Running Windows 10pro with a Cisco-Linksys E900 wireless n300 Router.
Works fine until the printer goes to sleep or auto turns off. then when a new print job is submitted, it does not wake up (like the description says it is supposed to do). I have to go over to the printer, turn it on, wait a minute or so, then the queued-up print jibs startr to print.
Did I set up something wrong, is there a way to disable "sleep mode", or is this a feature that is described wrong in the literature?
Do I have to live with this? It's kind of a nuisance when using laptop from other end of the house...
03-26-2017 09:00 PM
03-27-2017 06:44 PM
@dc9guy wrote:
I just found the answer. Read this link: http://ugp01.c-ij.com/ij/webmanual/Manual/All/MG3600%20series/EN/UG/ug_changing_settings0970.html
I'll give it a try. Man, this printer is complicated - so many buttons - seems like features like this should be accessible from a control panel or dashboard on the computer (that's how I was able to get it to never go to sleep (or auto-power-off)), but I can live with it. It was a very inexpensive printer and it works very well for the cost.
Thank's for helping me out.
04-04-2017 10:14 PM
@dc9guy wrote:I just found the answer. Read this link: http://ugp01.c-ij.com/ij/webmanual/Manual/All/MG3600%20series/EN/UG/ug_changing_settings0970.html
I haven't tried it yet, been too busy to re-enable auto-power-down mode. I believe it since it's from the manual.
03-26-2017 08:51 PM
I have the same problem. The quick setup quide says to check the online user manual for instructions for it to wake up but I can't find the information in that guide. If you find it, will you please let me know?
03-26-2017 09:00 PM
03-27-2017 06:36 PM
@dc9guy wrote:I have the same problem. The quick setup quide says to check the online user manual for instructions for it to wake up but I can't find the information in that guide. If you find it, will you please let me know?
OK, I will. I did figure out how to disable sleep/auto-pwr-off mode. So that's what I have done. Haven't had a problem since. But still, it's not supposed to be that way.
03-27-2017 06:44 PM
04-04-2017 10:14 PM
