01-07-2020 09:00 PM - edited 01-07-2020 09:17 PM
Hello.
I amusing a PIXMA MG3520 printer and any attempt to print a PDF through the PRINT app results in an undefined error...
"Canceled the process because an error occurred."
This message is preceded by the typical Data Conversion Service message.
I was able to print through Google Cloud Print, but I won't be able to use that option soon with the imminent shutdown of the service.
Any ideas what could be causing this?
01-08-2020 09:49 AM
,PDF appications are not universal or created equally. Adobe is the industry standard.
Did you create these documents or were then created by someone else? What application?
Does the error happen with every .PDF document, or just one?
01-08-2020 10:17 AM
This has recently happened with multiple PDFs from very different sources. I haven't had these problems in the past, but it can be months between using the printer, so I can't say exactly when it started.
The most recent was some print-at-home tickets for a hockey game.
01-09-2020 04:07 PM
Hello.
Try performing a PDF scan with the app. Then print the scanned PDF file. Does the same error occur?
01-12-2020 09:47 PM
Sorry for the late response. I was away on business.
I did as you suggested and was able to print the PDF that was created from the scan.
I continue to be unable to print other PDFs, no matter how I initiate the printing process
