12-26-2025 06:30 PM
Printer worked yesterday. No software changes observed. Uninstalled driver, restarted, reinstalled, same result.
12-29-2025 01:39 PM
Canon quit supporting parallel printers in 2003, but that is not the real issue, your printer does not have a parallel port. So how are you actually connecting to your computer? Wifi? USB/printer cable? If you were connected to LPT1 was it a virtual wireless port used for a network or a usb to parallel adapter?
12-29-2025 08:44 PM
Thank you for your support. It turns out that the problem was the pdf file I was trying to print. Other files have no trouble. Now I need to find another way to obtain the form.
12-29-2025 08:55 PM
Now I see this. I was going by:
12-30-2025 05:07 PM
Thanks again. The customer service phone number was what I needed.
