11-29-2014 02:37 PM
Hello comunity,
I have new Canon Pixma MG 5650, but after new firmware it stops scanning to PC via USB. It copy everything so hardware is good, but when i want to scan something into my PC it shows.,please wait.,and than nothing it just return to menu where I choose documents-photo-auto 😞
Scanner dont even turn around :(((
Please help, cannot see any option to test scanner 😞
THX
Tom
08-31-2015 04:33 PM
Printer and copier ok Scanner not scanning
Anybody got a solution or are we just listing a problem
10-08-2015 04:49 PM
10-09-2015 02:57 PM
Been having a tinker with the scanner and ....... it worked, I scanned a document to my pc and here`s how ........
Put the document to be scanned to you PC on the platen and close the lid
From the home screen on printer,
1. Select `COPY`
2. Select `PREVIEW` .. the first button of 3 under screen.... the scanner will start scanning, and then when it`s finished
3. Select `HOME`` ... the button next to the power switch
4. Select `SCAN`
5. Select `Save/Forward` ... the first button of 3 under screen.
On the printer screen you should see `Forward scanned data to a PC`
6. Select OK button
Highlighted on the screen will be ` Local (USB)`
7. Select OK button
Highlighted on the screen will be `Doc Type -Auto scan`
8. Select either the `COLOUR` button ( If you want a colour scan ) or `BLACK` button ( If you want a black scan )
It should now be scanning your document and then transfering the image to your computer.
Seems a bit long winded I know, if someone has a better way please let us know.
Hope this Helps.
11-13-2015 01:05 PM
But where does the scan go? I ca't find it on the PC!!
11-13-2015 04:19 PM
In my particular case it opens in a programme called .... `Canon my garden image`..... This is probably the default programme that is built in with the mg5650.....It loads up about 30 seconds after printer has scanned the item to the pc. I can then drag and drop my scanned items into my folders.
01-24-2016 11:02 AM
Hi!
I own a MG5650 and I had this problem too, but then I found a solution.
All I did was run the CD-ROM that came with the printer, then pressed CHANGE METHOD.
I had ticked the box where it said connect with LAN etc. from before, but then I changed it to connect with USB, the lower one.
I then did the normal settings on the printer when you start to scan (from the home screen ya know), and it worked!
I hope this helped somehow, like it did for me. 🙂
Best of luck!
magicnettle
09-06-2016 04:18 AM
Try going on to the canon support site search for mg5650, click on the downloads and bascially download and execute all the software and driver updates. Takes about 20 mins and a bit of patience.
Follow all the on screen prompts and then you will see your pc listed correctly on the printer. (not just usb)
Then try scan as per normal and it works...well it did for me.
09-14-2016 10:45 AM
my Canon MG5650 does not scn to computer. Printer and copy function is working. Help please.
06-23-2017 08:53 PM
OK...so where does the bloody image go?!!!
