MF Toolbox errors when trying to display scanner driver
crlgllsp
I have an ImageCLASS MF4890dw connected via wifi to a Windows 8.1 desktop.  I have installed the drivers and the MF Toolbox from the support site.  The printer function works fine.  And I seem to be able to scan a document by selecting PDF in the Toolbox and then pushing the green Start button.
However, if in the Toolbox I check "Display the Scanner Driver" and then select Start, I run into problems.  The scanner driver window opens, but when I select either Preview or Scan, the scan fails to complete and gives error code 155,0,0.
I have completely uninstalled the printer, drivers, and toolbox and then reinstalled them according to instructions I read on this site.  The only difference is than I have my printer connected via wifi rather than USB.
Any Suggestions?
0 REPLIES 0
