11-13-2024
07:36 AM
08:06 AM
James_C
I printed ordinary black and white text, using my long-time text editor program. The result is so faint I can hardly see it. How do I increase the darkness of the text? The G3270 also prints address labels too lightly using standard shipping program ShipStation. Please, somebody help!
ADDED:
I found a partial solution. I used Windows Notepad, changing the font to Consolas 11. It now prints a bit too darkly. Gosh, most copy machines offer a variable darkness control. Why doesn't G3270 offer this? And why doesn't it offer a computer screen preview showing what the printing will look like?
11-21-2024 10:34 AM
I found a solution! Turn printer on. Goto Windows settings > Printers & Scanners > Canon G3070 series (default) > Printing Preferences (wait for dialog) > Paper/Quality tab > Quality Settings. The default setting is "Better". Change it to "Best". Printing will be a bit slower but darker. This will work only temporarily, and the setting will later be found to be "Better" again. Maybe someday Canon will provide a Darkness control, or make it easier to print good colors.
11-13-2024 08:20 AM
ADDED:
Have you run a nozzle check?
Print and Examine the Nozzle Check Pattern - G3270
11-13-2024 10:25 AM
No. (1) it's a known problem with this model, (2) it's a new printer, so it can't have clogged nozzles.
11-13-2024 10:30 AM
Then I recommend you contact Canon support at 1-800-OK-CANON.
11-21-2024 10:34 AM
