Ink Cartridge stuck in Pixma MG7150
andy5
I was trying to carefully replace the yellow printer cartridge on the above inkjet printer, when the locking tab sheared off, I was not using any force, just finger pressure as usual,  so I assume it was a plastic failure in situ.
Now I have the cartirdge stuck in its slot , with no apparent method of releasing it. I have tried gentle persuasion, and removed all the other cartridges to get a better purchase, but it is securely locked in place.
Is there a procedure to release it please?
Thanks in advance
Andy G
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to The Canon Forums!
We appreciate your participation, though we need to let you know that your product appears to be a model that is not supported by our team here at Canon USA.  The Canon Community Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click HERE and select your country to find support in your part of the world.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA
A very thin blade and gentle touch should allow you to release the "stuck" cartridge.  You might as well use it up until it needs to be removed.
