04-12-2016 06:45 PM
I have a new MX922 on my iMac newly upgraded with El Capitan (10.11.4).
How do I fax from my Mac?
I've been all through every tab and setting I can find with no luck.
Help! 🙂
Thanks.
Dan
04-14-2016 11:43 AM
Hello.
Faxes cannot be sent from a Mac computer. It is only possible to send faxes from a computer running Windows.
In your case, you will have to print the item and fax it directly from the printer.
04-19-2016 09:47 AM
Why is it broken like this?
When will it be fixed?
Thanks!
04-29-2016 11:45 AM
Anything?
04-29-2016 12:48 PM
Hello.
This function has not available on Mac OSX computers for any of our products. This may be related to the printer/fax setup on Mac OSX. To send faxes from your Mac, you will have to use the fax modem adapter that is available through Apple.
06-28-2016 08:13 AM
Other vendors apparently have managed to configure their drivers to fax directly from OS-X El Capitain. I think the operative word here on Canon's part is "Won't" rather than "Can't".
I hope this enhancement will be considered for a near-term driver update.
06-28-2016 01:28 PM
This is a huge failure on Canon's part and I cannot see why they do not address it.
06-28-2016 03:57 PM
Apple seems to have broken one of the sacred rules of software engineering, "Do No Harm". Apple released a new OS, and broke much of the software base in the process. In other words, many applications stopped working properly.
This may not be entirely Apple's fault, though. Software engineers are supposed to follow certain rules when interacting with the OS. If the rules say make three left turns in order to turn right, then that's what you do. Some folks just take the shortcut and turn right, which usually results in broken code down the road. Like right now.
It has also been reported that Apple is about to introduce a version 11 of its' operating system in the fall, too.
06-28-2016 03:59 PM
That's not the way Canon is spinning it.
