09-30-2013 08:32 PM
When I go to print, it keeps giving me an error message that I need to put paper in the upper tray. But, that tray is just for envelopes and smaller size paper. Is there a setting I need to change??
10-02-2013 12:28 PM
Hi fsuher,
A couple of things we can check:
04-12-2014 11:32 AM
I have the same problem. I'm using 8.5 x 11 paper, trying to print from an iPad. I was trying to print a recipe from a Kindle app book but couldn't. Did research and found that Kindle is difficult to print from. I then did a screen shot photo and tried to print the photo of the page. This where I am now, and the printer says there is no paper in the upper tray (that won't fit 8.5 x 11 paper).
04-24-2014 06:35 PM
Hi parkerds,
When printing via Apple AirPrint, the paper size is selected automatically according to the application software being used on the iPad, and the region in which AirPrint is used; it will select the appropriate tray based on the paper size that was sent to the printer by your app or document. Please check to see if your app allow you to specify a paper size or document size before sending it to the printer. When Apple's photo application software is used, the default paper size is 4x6.
If you continue to have difficulties, please print the image from our Easy PhotoPrint app. This app is available for free from the App store and will allow you to specify the paper size before printing.
Hope this helps!
04-30-2014 04:41 AM
For your convenience you must check down the setting of paper format and the size of paper you have putted on the tray.
11-15-2018 10:22 PM
11-16-2018 08:26 AM
Hi, Bamma!
So that the Community can help you better, we need to know exactly which operating system is running on your device (i.e. Windows, macOS, Android, or iOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
11-21-2018 01:47 PM
Bamma,
To print photos from your iOS or Android device and your MX922, please use the Canon PRINT Inket/SELPHY app.
11-21-2018 06:54 PM
Using iOS - iPhone 6s 12.1 and iPad 12
11-25-2018 09:59 AM
Thanks
