11-12-2013 01:08 AM
I have a Pixma MP560, I cannot get it to print black text. It prints color with no problem. All cartridges are full. When I do the nozzle test, the black ink is barely legible. I have done multiple deep cleanings but it has not resolved the problem. Do you have any other solutions?
11-19-2013 06:46 PM
Hi there,
I just thought I'd reply since this problem drove me up a wall and there was an embarrassingly simple solution.
I'd tried cleaning/deep cleaning a billion times and it was never getting any better, and my ink levels were just being depleted from the process. STRESSFUL. But actually after calling in, I was asked to check whether there was a slit above the ink label (like an upside down L) on the large black cartridge, and I had to remove a bit of a packaging sticker to see if it was there. It was this sticker remnant that was actually blocking the slit and stopping cartridge from being used properly. I don't know how this works exactly but that's how it went down. After removing the sticker, it printed black like a charm.
SO, if you've tried cleaning more than should be necessary and it's not a problem with the print head, it might just be a bit of sticker that is causing your problem. Thought I'd share, just in case.
06-26-2014 12:48 PM
@louielouielouie wrote:Hi there,
louie, were you using canon ink or a knockoff ink? my tab is totally removed on my cartridge label and it still wont print black.
12-29-2014 03:33 PM
Thanks for the tip, but that wasn't the problem with my MX870 printer. Not quite two years old...over $350...and it needs replacing already. Boo, Canon.
03-06-2018 01:37 PM
07-31-2014 04:38 PM
I tried your suggestion (even tho its my magenta that won't print) and no luck. I have replaced the cartridge a number of times. Last time Canon sent me a free one because I couldn't get the one before that to work. Now that the free one is empty, I have installed a new one and back to the same old problem.
Do you think there is a problem with Canon's cartridges being old?
01-28-2015 07:43 AM
02-17-2015 03:45 PM
Removing and cleaning print head works....Watched YouTube video (https://www.youtube.com/watch?v=ZheZf-vdho8) on cleaning Canon print head. Easy to do and after watching and then washing under hot water (ran black and blue) reinstalled print head and printing was back to normal...thanks for the lead
02-18-2015 01:06 PM
It's about time Canon admit they have a problem, and offer real solution.
Luckily, another user in another thread found it on his own... watch the video and follow instructions (I used canned air to make sure all water was gone - just in case...
http://community.usa.canon.com/t5/Personal-Printers/I-have-a-pixma-MX882-printer-and-all-of-a-sudden...
Worked like a charm on my PIXMA MX882
12-20-2016 11:43 AM
Hi Tropen. I tried to use the link but it doesn't work. Is the information available by anothe route? Thanks.
