07-18-2016 01:58 PM
I have MP560. When I scan a photo 8"x11", it only scans 4"x6" portion of it.
How can I scan my photo of size 8"x11" from the printer console and save it to my USB drive.
07-20-2016 08:59 AM
Hi r_vig,
To scan a letter sized item with your PIXMA MP560 and save it to your USB drive, please follow these steps:
1. Turn your PIXMA MP560 on.
2. Select Scan on the HOME screen, then press the OK button.
3. Insert the USB flash drive into the Direct Print Port or the memory card into the Card Slot.
4. Select USB flash drive then press the OK button.
5. Specify "Letter" on line 2 then press the OK button.
6. Load the original on the Platen Glass following the instruction on the LCD.
7. Press the Color button for color scanning, or the Black button for black & white scanning.
04-12-2024 12:13 AM
Patrick, this is close to what worked for me, THANK YOU, I've been looking for this answer for YEARS! That's because I've been going through the NAV screen, where the default is 4"x6" and it didn't seem like it could be changed.
04-12-2024 12:57 AM
Patrick's answer was the first that I've seen that broke my logjam of frustration in not finding this answer anywhere. It sounds like you were using the NAV1 route, where 4x6 is the default choice. As I have dozens of photos to scan, doing this one by one would be painstakingly slow as well as off-putting, which is why I haven't done it for years. The existing documentation didn't cover, ironically, navigation.
2. Press the HOME button.
3. Rotate the wheel around the OK button with your fingertip until you reach Scan, then press OK.
4. Insert the USB flash drive into the Direct Print Port or a memory card into the Card Slot.
5. Rotate the wheel around the OK button with your fingertip until the medium you're using appears: USB flash drive or Memory card, then press the OK button. Press the OK button a second time.
6. The default or the last settings you used appear. To change these, use the Down arrow to get to the size, press OK. Navigate to Letter (or whatever size you want, A4, 4x6, or 5x7) and press the OK button.
7. The default is 300 dpi. If you want something different, e.g 150 dpi for lesser/Low and 600 dpi for the best/High on this scanner, use the Down arrow to get to the dpi line, press OK. On the next screen navigate to the dpi that you want, then press enter again.
8. The default type is PDF. For a photo, you'd want to use the down arrow to highlight that, press OK, then on the next screen use the down arrow to highlight JPEG, then press OK again.
9. Next should be highlighted in gold (it's difficult to tell) at the top of the screen, press OK. Press OK again to continue.
10. As shown on your printer's small screen, load the original on the Platen Glass following the instruction on the LCD (facing the printer with the buttons on your right and the platen on your left, the upper left corner of the platen is the top left of what you're scanning).
11. For color scanning, press the (green) Color button, for black and white scanning, press the (white) Black button for black & white scanning.
