03-21-2013 08:02 PM
Yes, I was able to use my scanner couple times then went to use it again and get this error message that says the scanner is not available while in use by another application or user. This is weird as no one else has used my scanner but myself and I have shut the printer off many times even unpluged it and still won't scan to my computer. I hope someone can give me some advice so I can get it up and running again.
Thank you
PH
03-21-2013 08:58 PM
Hi PH!
To have a better understanding of your issue, please let everyone know which model Canon Scanner you own. That way, our Canon Forum members and our Subject Matter Experts will be able to assist you with suggestions appropriate for your model. Please also let us know what operating system you have installed on your computer.
Thanks!
03-21-2013 09:55 PM
Hi Naomi
Thank you for the quick reply. I have a 3 in 1 Cannon MX 310. I am using Windows XP operating system. If there is any more info you need please email me and thank you again for your help. ![]()
PH
03-24-2013 05:23 PM
Hello PH.
This error should be resolved by restarting your computer. Please restart the computer and then try using our MP Navigator program to scan again.
Let us know if the issue persists.
06-10-2013 05:52 PM
I am having the same problem but I do not have time to turn off and on my computer ever single time I need to scan something, which would have to happen as I have already turned off and on my computer once. I was then able to scan one thing and then I got the error message... again. I have had this scanner for years and it has never done this. I am using the CanoScan 8800F.
06-13-2013 12:44 AM
Hi carenson,
To isolate the issue you describe, please follow these instructions to put your computer in a Selective Startup:
1. Press the Windows key on the keyboard and then press R.
2. In the Open box of the Run window, type msconfig and and then click OK.
3. In the General tab of the System Configuration Utility window, click on the Selective Startup radio button.
4. Remove the check in the Load Startup Items box.
5. Click the Services tab.
6. At the bottom of the Services tab, click Hide all Microsoft Services box. The window will refresh.
7. Under Service column, uncheck each box that is left in this tab.
8. Click Apply and then Close.
9. Click Restart.
10. Proceed to use your scanner to see if the issue you described has been corrected.
11. After using your scanner, repeat steps 1 and 2, click Normal Startup and then restart your computer.
Are you able to use the scanner while in selective startup?
06-30-2015 05:56 PM
