04-29-2020 07:48 PM
Dear Canon Community,
I have been unable to get multiple pages to scan in as one document. I always end up with each page as a separate document, what am I doing wrong? Please advise?
Thank you.
04-30-2020 09:29 AM - edited 04-30-2020 09:33 AM
I have an MX472, so there might be some differences, but when you use IJ Scan Utility do you not get this window:
And this option in Settings?
04-30-2020 10:44 AM
04-30-2020
10:33 AM
10:41 AM
Thank you for replying. So, I am NOT tech savvy, I did manage to find out how to download the Canon IJ Scan Utility. I will try this in a bit when I have time to close out all my apps and unplug the printer etc etc.
I will let you know if I have any success. Thank you again!
04-30-2020 10:44 AM
04-30-2020 11:03 AM
You can also use the Automatic Document Feeder (ADF) located at the top of the printer. It's a little faster since you don't have to keep opening the lid and replacing each page one by one but the quality is not as good from my experience. I only use it for text documents. Place all of the pages into the Automatic Document Feeder facing up with the top end in first. Click the Scan button on your printer. Then, make sure the Save/Forward location is set to PC (Local USB). When you are ready press the White button located on the right side of the printer if you want it to scan in black and white. If you want to scan in color press the Green button. It should automatically get saved to your computer as a PDF. I hope this helps.
04-30-2020 04:06 PM
IT WORKED!!!!!! THANK YOU!!
04-30-2020 04:07 PM
