How do I clear a B200 error on a MG5220
marthagill
I tried suggestion on line and even removed, cleaned , dried and reinstall ed the print head - no luck.
17 REPLIES 17
Can confirm ewil99's fix still works! Thanks!
It worked!
Worked GREAT!! First Try..THANK YOU
Ewil99'ss- June 10th 2021 you saved me from buying a new printer.  Been working on this for a week before I found your solution which worked first time!!!!! THANK YOU!!!!
THANK YOU!!!!!
jwt1999
ewil99's solution worked for me, the first time I tried it. Terrific. Thanks!
I did this step by step on my printer then it just turned off and I can't get it to turn back on. Help
tried today on MG5250, worked on second attempt!
BRILLIANT SOLUTION!
Friends and Family
